Hello All,
I have an old Abercrombie and Fitch Ship mate watch that has a helvetia 81 movement (or a ZentRa 6/70) and it needs a new hairspring / balance wheel assembly.   Does anyone know if another cal of the Helvetia (General watch Co. ) is compatible with this movement. I believe it is 10.5 lignes and have a great deal of trouble finding a donor movement for the 81.
Thank you again.
Edited by cduke
add photo
You can check bestfit or Jules borel if there is any compatible balance . Bestfit catalog you can find on the forum. Search bestfit .
Edited by rogart63
Have some old movements laying around . somewhere in the back of my head i have something that could be a Helvetia 81. But if it has a balance wheel?
I appreciate your interest in looking. I am sure something may turn up on ebay one of these days. The best fit manual lists nothing for Helvetia.
Sorry had nothing. Have looked around and seams difficult to find.
I am now trying to match a balance wheel from another 10.5 lignes movement to the balance cock assembly!
Desperate times call for desperate measures...
Can work. I did it on a Eterna movement so can be done. Hope you work it out.
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
