Regulator Clock
oldhippy
Here is a lovely Regulator Clock with stunning photos of the movement. If you have wondered why these clocks fetch high prices, you can see all the little intercut pieces that make up the movement right down to highly polished screws. You can see the maintaining power, and how the oil sinkholes are covered and have screws to take up end shake, this is so the gears rotate on the same and even line and helps with keeping such precision time.
https://www.ebay.co.uk/itm/16-DIAL-STUNNING-JEWELLERS-REGULATOR-LONGCASE-CLOCK-fusee-mantle-bracket/254008841663?hash=item3b241b55bf:g:6tkAAOSwNqRcBAyu
