T ended mainspring
LiamB
What is the best way to fit a t ended mainspring? I find them quite tricky to get in. Does anyone know any special tricks? And, is the method different when using a mainspring winder and when fitting a new spring still secured by ring.
Thanks very much,
Liam
to insert a T end mainspring you need a mainspring winder. If it's in the ring it has to come out it can only be done with a winder. You wind the mainspring into the winder leaving little bit out. Then wording is going to suck for how to do this. Insert the end of the mainspring in the barrel first followed by the winder itself. Then you should end up with something like in the picture the winder and the mainspring in the barrel. Then you rotate the winder until the T is over the hole or slot. then press it into the opening verify on the other side that it is in the opening. Then before pushing the spring out you need to hold the T end down. You can either use the end of your tweezers or I usually use the largest screwdriver I have. If you hold the T part down into its opening now you can push the whole mainspring out it will stay where it is supposed to be.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
