Showing results for tags 'seiko 7009'.
Found 2 results
  1. I recently bought a Seiko 5 7009 which turned out to only run intermittently. After taking it apart and giving it a clean I went to reassemble but struggled to get the escape wheel and pinion to sit between the jewels. I think it looks like it might be slightly damaged at the top and was wondering if anyone agrees? It's part number 251012 and I've attached some images below. If it does need replacing does anyone have recommendations of where to find them in the UK, the only ones I can find seem to cost more than a donor non-running movement. Is it a part that is commonly broken or would people take the risk on a donor? Thanks, James
  2. Morning everyone, I have the following Seiko 7009A watch with a huge amount of rust damage: I took this on as a personal challenge, I have a question regarding the dial feet retaining screws, these are the eccentric screw type: One of these feet has rusted and crumbled away to nothing, leaving a hole where it should be. Anyone have any experience on how to replace these? I have a donor movement so I can find the part, but need help/advice on how to install it. Or is there another method I can use to secure the dial? Dial dots etc will not work as they will fowl the day/date discs.
