Cheap German wall clock repaired
GeorgeClarkson
We received from an old lady that passed away a couple of years ago this cheapo German wall clock. It was working nicely until our last moving, during which someone or something pulled one of the two hanging chains a bit too far, breaking a ring and letting it completely fall off the clock. I decided it was time to repair it...
This is the inside of the clock. As you can see, it is a cheap clock, so not really worth repairing, but why not?
In the first picture o had already removed the right (how is that thing called???), the one that makes the "cu" sound.
What you have is a 30-hour mass-produced cuckoo clock; there is a knack of fitting the chain, it is possible to do that with the movement still in the case. They are called bellows that make the sound; todays are made out of synthetic material. Old antique original cuckoo clocks the bellows were made out of goatskin and the clocks would stand on tables they did not hang on walls and they were spring driven with a fusee movement. Well done in sorting it out, they are fiddle little sods and many clock repairs will not touch these modern types. It has a good beat as well.
I was hoping you would chime in. Thanks for the info and yes bellows is the name, only that at 22:00 my mind was a bit tired... It is 8:00 in the morning and I just heard, precisely at the hour change, the cuckoo sing. Delighted to hear that even if it come from a mass produced, cheapo wall clock. And a couple of seconds later, the gong of the other wall clock in the living room just reminded me I am late for work... More pics of the cuckoo later.
I forgot to mention the early cuckoos were made of wood and the wings would lift as if to be flapping/flying, modern ones are made of some type of plastic. It looks like you have all the info on the back plate, enough there to find out more about your clock.
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
    • When building a new Watch I have tended to use a file to remove the remnants of dial feet that are not needed as many dials come with four feet to accomodate different movements, but this can be a bit messy so now I use this with a great deal more precision as you can use an appropriate bit for the job and keep it very localised.
