Hey Mark
Yeah! Me too. A Certina movement as a matter of fact. I haven't started working on it yet. I got sidetracked by an UT 6498 equivalent to the ETA 6498-1 which is another option for that tool kit...and of course by about 15 other movements I had laying around the house and/or from ebay! I couldn't make that brand new movement my first victime at the time.
In any case, once you case it you'll love it! You'll see!
I did all 3 levels at the same time...I can say I'm still going back on and off. The trick is to do the whole watch as it "should". By having all three levels you end up servicing and regulating the first and second movement they tell you to work on. In the end, the watch you make is completely ready for normal wear.
If you only do level one, the movement is not fully serviced. Normally you will either loose something or break something that has to be replaced (make it an AND sentence for wost case scenario). When you finally assemble the movement and "build" your watch, that movement is not properly clean and lubricated for everyday use. The wear and tear on the parts are excesive and to correct that you need at least level 2.
After learning how to clean and lubricate (lv 2) then you adjust the watch in Level 3. Then your watch should be a dependable and accurate timepiece!
So in a nutshell, that's the complete class experience!
    • Thanks Ross, yes i remember the broken arbor screw you had to deal with. Dont give up, if i can drill a tiny hole in a bloody hard barrel arbor without breaking the drill bit then you'll get that screw out one day somehow .
    • Isn't it most correct to say that the mixture of radium decay pathway compounds found in old lume will produce both alpha and beta particle radiation as well as gamma rays, so it's over-simplistic to dismiss it all as low-energy particle emission? True, a cheap geiger counter chirping away with a raw CPM count won't specifically give you the relevant biological dose, but it makes it easy to tell the difference between your local background, a watch with a bit of activity, and one that is comparatively quite active. Each person can make their own risk analysis based on their understanding and concern, but there's nothing wrong with using an inexpensive meter to help make the determination.
    • A lesson I learned last month on a Junghans pocket watch where both pins were bent over like stalks of wheat in the wind. I bent them back straight, wondering what a shock the thing must have taken to somehow bend even the outside pin over. And then the escapement wouldn't unlock at all. Probably the pallet stones are too long but I'm not ready for that repair yet so I bent the pins back over and it runs 0/0.2
    • Never. Brilliant work and photographs. Thank you. On my very first watch I knackered the arbour. I think the screw I put in was the crown screw. I didn't know about left handed screws then. Head sheared off. Thread broken just below surface. If I had the space, then a lathe would be my wished purchase. 2 1/2 years later and I still get the arbour out now and again and...... I can dream. It's a lovely pocket watch. Ah well.
    • Hello Davis. This thread is interesting. Thought I'd add my twopenneth worth. A short while ago I had a similar problem to you. Not a broken banking pin, but I did alter a banking pin. Much to the consternation of members. Rightly so. However I did as they suggested and obtained a complete donor movement and installed it into the watch. The client, who I did not charge but did the work as a project for myself, was as happy as Larry.  Can you not look for watch of the same name? A Donor watch or movement.  Keep us posted on your result please.
