Amplitude
jnoble
Hi everyone, Im new to this forum and I have a technical question and maybe someone could give me some advice or share some tip to resolve this problem. The thing is that I just service an ETA 2836 2. Once the job is finish the movement starts very strong with a good time reading, Beat error 0.6ms, Ampluitude 267 etc. but in a lapse of 24 hours the movement begins to loose time and the amplitude drops dramatically at the point that the movement completly stops.all pivots are in a good condition, not broken or chip jewel. This movement is completly strip, just the train work is in place. Please help.
Checked all the teeth on the barrel? Is there any dirt trapped between any of the teeth?
Same with the great wheel and pinion.
Endshake and side shake of barrel - can the barrel lean over enough to touch any of the wheels - you can check the barrel bridge, is there any scoring under it or under the ratchet wheel?
Hopefully you can see where I am going with this.
Also - check the hour wheel teeth, is there a calendar? If so then remove the calendar work and test again, maybe the changeover is causing the problem.
Check the free running of the train - e.g. fully assembled without the escapement/balance and manually turn the wheels (with the keyless and motion work assembled) make sure it turns for several cycles of the barrel - slowly and with as little pressure as possible, if the wheels become erratic then remove the motion work, then work your way all the way to the barrel checking all the teeth and pinion leaves to make sure no grit or dirt is wedged in where it should not be.
Hope this helps.
Thank you so much. Im going to check every detail that you pointed me. I will keep you inform of the progress. Ohhh and by the way let me take a couple of lines to tell you that I admire you as a professional, because you are one of the few persons in the trade that doesnt have fear to pass your knwoledge to help others. In my case I have to turn to a person that is 6,600km apart from me to get any help or advice. Once again thank you so much for your help.
    • Nice interesting diver Razz, i have a sheffield dress watch, different movement altogether. Could be a wrong motion works part, how does the setting feel before fitting the cannon pinion, clutch and intermediate wheel meshing ok ?  The less traditional setting design could be suspect, the second wheel has a slip clutch assembly, that most likely needs looking at. LA is 42 ° Razz Tbh i  much prefer to call the complete unit the lever, then use the seperate names for all of its components. Such as guard pin, fork, fork horns, fork slot, lever arm, pallets , pallet arms, pallet slot, pallet stones. I suppose pallet fork is the combination of the two opposite ends that make up the lever, its also called the anchor which is descriptive of its appearance.  Its a pretty basic 1930s  swiss lever movement H and yes Nev was meaning the pallet fork.
    • The pallet fork should really be called a lever, English lever, Swiss lever etc but most people including myself call it a pallet fork.
    • Seiko have case numbers, I  can't see it on your photos.  If you can find that we can look for a genuine crown.  If not, you need to measure the diameter of the stem, the distance between the lugs and the depth of the lugs.  The case number will be something like this.
    • I'm not sure what kind of movement this is, but I'm curious to know if you're using the word "lever" as a synonym for "pallet fork"?
    • Actually kind of rough, maybe munute wheel pinion problems? Is the 2.73mm canion oinion which seems rarer and not availble on Cousins UK. The seconds hand works and suprising nice amplitude but don't know the lift angle and BE this one says 17 j but is a pin pallet as well. Cap jewels on the escape and drive train pivots. Interestingly in has both water proof and shock resistant on the caseback and dial. Puts this around 1969 or '70? The double bezel that works independently is cool has the pi symbol on each. Wonder if it can be used like a slide rule ir something...
