Grandfather Clock mechanism holder
Your diagnosis of a missing screw is probably correct - the tip of it should be visible in your photo but is not. However, installing the screw still may not fix the problem if the Date Click Spring (2576) is worn out. Those very thin metal parts can wear down where they insert into the plate, causing them not to stay affixed as well as they should. But replacing the screw first would be good to test. I do not think it is the same screw as in the rotor. In the M31 diagrams, the rotor screws appear shorter than the "short" pillar screw. But the screw threads should be the same for all the pillar screws, for all Timex movements. If you obtained a junk Timex movement from ebay or elsewhere and removed one of the regular pillar screws (5100), I expect it would fit that hole. I think you could use any Timex >M24 mechanical movement to get a fitting screw. If it was too long protruding and interfered with something on the back of the movement (like the rotor), you could file the tip of the screw down until it no longer got in the way. I suggest this because again, I do not expect a watchmaker to be willing to help you source this part.
Hi All I’m Mark a new member from the UK. I have a long standing interest in clocks and very recently pocket watches. I ended up here after purchasing a minute repeater in a rolled gold hunter case and looking forward to seeing repair advice on this. I hope to have lots of fun with my new found interest and I look forward to hearing from you soon. Thanks Mark 👍
Any way to fix dials to movements you can think of and more has been tried Glen. The dial is maybe not original, to the watch. The problem with dial dots, if the adhesive gets for whatever reason, they ease up on holding the dial in place. Attaching feet is a nice permanent solution, if you want to go to the trouble of it. Its a tricky process with risks however you do it. I'm not sure I've seen dials without feet before, but probably. Often they are there and only push on to the movement with dial feet screws. -
Hi everyone, An update. First of all, I would like to thank you for the information provided, it was very useful help. I was supposed to take more photos but with the beginner’s stress I ended up forgetting. The watch was assembled in a Timex factory in Portugal (my country), 50 years ago (a piece of history that no longer exists) I followed the procedure described in the technical manual until the part of removing the hands (were misaligned) . At that time I noticed that the Date lever was out of place. Once placed correctly, everything was ok and the date started to change correctly. Since I had removed the hands, I adjusted the change of day and day of the week, which was changing too early and cleaned the dial. At this point I thought everything was ok, but during tests to check if the day and date were changing at the correct time I noticed that the movement was slightly loose (the movement wobbles in relation to the Date Frame on the opposite side to the crown). I ended up closing the watch and leaving it like that and trying to use it. It turns out that although, when the day and date were set, everything worked as expected the next day the date didn't change. I opened it and I noticed that the Date Lever moved back out of place again (photo). My conclusion is that a screw is missing (5145/1 - Pillar screw (short)) and this creates a gap between the movement and the Date frame, causing the Date lever to move out of place with normal wrist use. Over the weekend I will try to see if everything works correctly without wearing it on my wrist. If it is confirmed that a screw is missing, can anyone tell me if it is the same one used to screw in the rotor? If that's the case, my best guess is to remove one of the screws from the rotor, take it to the watchmaker and see if he can get me one of identical dimensions. Any other ideas on what could cause the Date Lever to go out of place? Regards Vasco PS - Placing the second hand was a pain in the A**
