Latest Creation
Legarm
Very nice. What is exactly concaving the dial? How is it done? Thanks!
I am just starting my Granddaughters watch, so took some photos...... First I chose the movement size and case then cut out a blank dial from 0.3mm copper or 0.5mm. Then I put the face, dial and movement into the case and see if the stem lines up with the stem tube, great if it does, but not often.....
Then put the dial in a glass press with the bevelled die on the bottom, easier to see it that way, flat die on top (choose dies carefully), make sure it's al in line and centred.
Then press gently until the desired concave is achieved......
This is my method, maybe there are easier and better ways.......
Like the way you went about it Legarm. It's all a bit clearer now.......I think, the initials are yours (or your granddaughter's) and you in Alkham, nice touch!
Did you print the dial yourself?
My initials, sometimes put the persons name on face if special occasion. Top watch is for my Son...... Design and print dial on quality printer, tried to age the top one....
Very impressed and with new views of what to do with dials. Thank you for the explanation Legarm. If you don't mind I have another question, what type of paper/material do you use for the face? I hope I'm not being too nosey but this thread has awaken all my interest! Thank you in advance.
Use various materials, high quality Canon Super Glossy 2 paper, sometimes paint dial with spray. Generally get inspiration while doing each project.
What I meant was - it's very similar to the ETA 1100, particularly in the triangular bridge, but not quite. Must check Ranfft!
Dead right Will..... near as possible the same............ strange that two movements with exactly the same configuration. Well spotted.
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
