Rotary 9ct Gold Case Repair
Outlaw
Hi all!
I've came across this lovely Rotary watch which has a 9ct gold 2-piece case. The problem is that a glass cannot be fitted to the casing as it has been squashed slightly or distorted and it is now uneven and will not allow a glass to be fitted.
Does anyone know of a reputable watch casing specialist/goldsmith? I know that this type of repair is pretty specialist as I've taken it to many goldsmiths who have told me that I need somebody who works with watch cases specifically as you need some sort of knowledge of how the casing is supposed to be...
I have tried contacting a few, including Adam Phillips at watchcaseworks.co.uk and classicwatchrepair.com but am not getting any responses?
Any advice would be fantastic. I've even checked eBay to see if I could pick up another similar Rotary to use the casing but it's a bit risky since it's 9ct gold and only a 2 piece case where most are 3 piece cases with the bezel containing the glass...
On 12/20/2017 at 10:29 PM, Outlaw said:
Hi all!
I have a Longines 9ct gold case with similar damage. The only person I found was Adam Phillips - he sounded ideal.
I sent him the watch in June and I haven't been able to contact him since July.
I'm getting a bit worried as it was a good watch.
Oh bless you. I have used Adam Phillips in the past for an 18ct fold Omega case that needed melting down and starting again. He did a fantastic job in fairness and in around 4 weeks if I remember correctly. The total charge was in the region of £900-1000 which is very pricey but its clearly a very skilled job and hes the only person that I could find so I guess he can name his price which could be very reasonable but I have no bearing for comparison...
Ive now sent the Rotary to a gentleman named Brendan Hoey at webwatchmaker.com who seems spot on. His website is very informative and his CV is impressive as are his examples and reviews so fingers crossed he can sort this Rotary casing for me. Ill keep you posted on the progress.
I really hope you are able to get in touch with Adam Phillips and get tour Longines back. Not to perpetuate any false stories or anything but when I was having my Omega casing done with Adam (a little over a year ago) I had to do a little bit of chasing after payment to get the watch posted. I spoke with his wife who mentioned he had a bout of ill health so I really hope that hes ok. But, as I say, that is just speculation...
Best of luck
David
Best of luck
David
Glad to hear you got such good service from Adam. I hopes he's OK.
    • Hello and welcome fromLeeds, England, it looks like you are well on your way.  Multiple accounts are against forum rules, if you give the name on the other account it can be removed.
    • That has become habit to quote since learning about electricity as a kid. I'm sure even my old school sparky (74) still uses divisions of 240v to work out current draw and fuse ratings. Uk  Rating on my travel kettle averages out at 230volts 😆
    • Hello everyone, My name is Matt and I like vintage watches along with pocket watches. I'm very new to the hobby of watchmaking, I've only been tinkering for about 2 months and I'm happy with some of the projects I've salvaged.  First I repaired This Waltham 17 jewel 18s and that was fun.  Then I repaired this old Zenith movement with 19 jewels. I couldn't find it on the pocket watch database though.  Then I repaired this one Lucerne 1 JEWEL movement. It was actually the first watch I got but it was so difficult to put back together with the fiscal amount of tools I had at the time so I just left it strewn in a Ziplock bag. Then My most recent project that came up a total win was this Longines Caliber 19AS, 17 jewels unadjusted. It turned out beautifully in my opinion and was by far the most difficult to reassemble.  I am in love with this hobby and its kind of engulfed my personality as of right now.  I plan on giving the Longines watch to my uncle, and so right now I'm trying to enjoy that watch the most I possibly can.    What I'm currently working on: A Seiko Automatic with a little date window and a weekday function too. I think its the 6309A.  Then there is this Omega pocket watch. Unfortunately I lost a little screw that held in the click spring. I'll have to source another one because its tiny and my room is filled with carpet, that thing is gone. Then theres this little tiny Elgin pocket watch. It's fully assembled but the amplitude is low and so I think it needs a new mainspring.  Then theres this Waltham 7 jewel movement that I also cleaned and reassembled, but it'll only run facing one way and again with the amplitude being low, I think it needs a new mainspring as well.  And finally, I'm working on this gorgeous Grade no.3 1883 Waltham Pocket Watch. It came with a broken balance staff on both sides and would only run when the watch was like sideways, crown to the sky. I'm really excited about that one though, might be worth something.      I've chosen to not show the other ones because they're not in movement holders right now, and the Omega is not put together.  As you can see, I take these pictures using the flash. Idk why but I like the way the flash makes the metal shine more than just my little lamp.  I'm also very eager to find a replacement for that balance wheel; any links would be appreciated.  From what I could tell on the Seiko, it's just dirty and It should run if I put it together carefully after cleaning.  Also, I fear that that 1883 Waltham may not run too good because of the mainspring, it's probably set because it's so old. I may seek a replacement for that too. I also need to find a crystal for that 18s gold filled Waltham that I've put together. It's just scary having it exposed.      I ALMOST FORGOT to mention. Is this Omega real?      You gotta turn your head a bit but it does indeed say "OMEGA", so I'm confused. I never knew they made pocket watches. And thats why I'm skeptical. Please let me know.    But thats pretty much it. I just wanted to put this out there so that I could begin using the website properly and also to let some people know I exist I guess.  Also this is my second account. I know that may violate some rules but I did the introduction wrong the first time and I wanted to fix it by making a new account. Please don't ban this one.    Thank you all, -Matt
    • Sounds like you and @VWatchie were unlucky. Mine has been running on 230V UK for years  ( it's been 230V for many years @Neverenoughwatches, not 240V).  Though I have had to re-solder some wires. When I buy cheap Chinese electrical components I often take them apart to check they're not going to kill me. Since the demagnetiser, I bought a cheap fish tank heater for my plating set up. Plugged in, big flash and smell of burning. Deader. So I bought a cheap cup heater plate. Exactly the same - flash, bang, wallop.
    • The old crystal is cracked on the edge, and I am looking for something like for like.
