Need to find a new balance cook and a new balance for a Eterna. Says 692 on the movement.Someone has glued the balance spring and the adjustment to the balance cook :( But can't find anything on Eterna 629?
Why can't something be easy?
Found this .that says Eterna 629. Unfortunately it's not available  anymore.
Edited by rogart63
Is this cock universal? And could be find on some other movements . Maybe need a new jewel also? But haven't work on a lot of this old styles jewels. DSC09087.thumb.JPG.f5ffb110a8a575b9f91ec4bc7a82749e.JPG
This is the movement. Can use the cock  but it has a bad repair. DSC09088.thumb.JPG.95ec528af99661a1b195ce42d354c401.JPG
How many different balances can there be. If i could find a balance with the right height and a impuls that moves the pallet fork. Has the same frequency as the 692. Think it's 18000 . So the hairspring has the right length . Do you think i can get it to work? In don´t the owner mind if it doesn´t run in Cosc . But could at least go within a minute a day.
Hi Rogart,  You start with 692 the flip to 629 ??
I believe that Eterna morphed into ETA.  There is an ETA 692 and a 629 movement which may be worth checking out.
Edited by canthus
I found one but not sure it works yet.. As the stud that sit in the balance cook is 0,5 mm and i am not sure what the hole in the bridge is. i didn't have a drill . Put will take a look tomorrow. If the endskake is to large can i move  the upper or lower  jewel? The impulse jewel moved the  pallet fork so that looked okay. But you  never now ? Hairspring to long what do i do then? Would make it 18000 if it has been i an old ETA movement right?
Edited by rogart63
    • I see. And is there a possibility to convert it to a springless system by replacing it with a standard split stem model?
    • Sharpening gauge.   I found the easiest side to do was the safety roller as the roller table laid flat on a block provided stability.  The other way requires a specific stump for the roller and pin to sit in, but may also grip better way.
    • Yes, the problem isn't so much with the 'background' radiation but inhaling or digesting loose flakes and dust that can become airborne.
    • The spring is so the crown pops out to the winding position when unscrewed.
    • Radium and the horrible story of the Radium Girls scares everyone - But there is also a lot of paranoia here.  I did a whole bunch of readings on a watch with Radium lume recently. My Geiger counter read 2µsv/h through the crystal with the sensor part of the Geiger counter right on top of the watch.  This measurement dropped off to the normal background rate of 0.18µsv/h as soon at the Geiger counter is just a few cms away. Measuring from the back of the watch and there is virtually no increase.  The rate went up to 5µsv/h from the dial and hands when the movement was removed from the case. To put this in perspective a Frankfurt to New York flight would give you about 50µsv of exposure and a chest x-ray about 100µsv.  Norwegian labour law states “The limit value for workers over the age of 18 years is set to 20 mSv per calendar year.” - that is the equivalent of 400 flights across the Atlantic! I will however point out at this point it is important that you don’t ingest the radium from the watch! One of the worst things you can do is scrape the radium off the dials and create radioactive dust that you could breath in! That being said… If for each radium lumed watch you work on you spend 15 minutes getting the movement out of the case and the dial and hands off and then another 15 minutes at the end putting the dial and hands back on your exposure would be less than 2.5µsv  Once you have the hands and dial off they can go in a box and put safely out of the way (probably good practice for any watch!). I believe the risks are negligible If you take precautions such as wearing a mask and gloves and wiping your work surfaces down with a damp paper towel and disposing of the towel, gloves and mask once you are finished
