I have a Ernest Borel Kaleidoscope watch and need help taking off the second and minute hands. How??
The darn app won't let me send pics. I'll try later.
I also have a Borel that I have been ignoring because I'm unsure how to remove those wheels without damaging them, clues would be greatly appreciated!
These watch appear similar to Zodiac Astrographics in that they use acrylic discs in stead of hands these discs on the Astrographic are removed by loosening the dial screws and lifting the dial upward thus removing the hands in the process my guess would be that these are removed in the same fashion obviously great care is needed
this page explains how it is done with the Astrographics
http://www.crazywatches.pl/zodiac-astrographic-oval-sst-mystery-dial-1971
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
