Tool Suppliers
Nigelh
20 is not much compared to some of the USA supply houses... I mostly use CousinsUK, Eternal tool (great screwdriver, and sharpener prices) then have what I need imported to the USA with expedited shipping for much much less. If it is about the same price I order locally from Kasker(great for mainsprings), and Esslinger. Sometimes I get lucky and find some tools on Micromark. I remember saving almost $150 purchasing my DE-415A demagnetizer from Micromark instead of ofrei.
There is also the second hand tool shops. Uncle Larry Watch shop, and Dave's tool and watch shop. And finally I most often use eBay for vintage tools that are quite costly new.
Hope that helps.
