Screw driver help
Douglas1701
2 hours ago, Douglas1701 said:
Could someone tell me the smallest screw driver to the largest screw driver i need for pocket watches and wrist watches?
Thanks
Hey Douglas,
Welcome to the forum.In my experience, You'll need these 5 sizes to get anything done:
0.60 mm Pink
0.80mm Yellow
1.00mm Black
1.20 mm Red
2.00mm Green
There may be a few brands that use screws sizes on either end of the spectrum, but these will get you through 99% of wristwatches and most pocket watches.
JC
Edited by noirrac1j
5 minutes ago, Douglas1701 said:
What about the .00 and .5 ? I ordered a set today that had those in it up to 1.5mm.
Thanks for the help.
The 0.5mm will work in place of the .60mm and you'll see the difference when you use those sizes. I suggest you use the screwdriver that is closest to the slot size to prevent slipping. This happens anyway, but will be reduced if you use the proper size screwdriver. I remember I was tempted to use smaller screwdrivers on the larger barrel or winding wheel screws and simply messed up my small blades when they came up short on torque and slipped. Lesson learned!
JC
Edited by noirrac1j
The reason i bout them that small was because i want to restore my gransfather wrist watch at some point in the future....there was a screw so small i could barely see it. That being said, the set was the only set i have run across that had that small of sizes...figured i better grab while the grabbing was good...it was a swiss set of 7 for $12.no one bid on it but me and one other.
doug
Edited by Douglas1701
doug
What type of watch is it? Can you post a picture or the caliber?
JC
2 minutes ago, noirrac1j said:
Its a beauty! We'll get that going...I'll help you in any way I can and so will the other fellows here. They're all top notch. Have you ever disassembled a watch before?
JC
No, just started learning and getting tools together...got a pocket watch movement on the way to start practicing on.
OK that's a good plan. You'll need good lighting (either regular bulb or fluorescent/LED type) and quality 10X loupe (Bausch and Lomb or something good quality) and a general magnification visor with 4X. You'll also need at least one movement holder and a mat to work on.  One more thing: a good set of tweezers! I got some from Ebay that are decent, but they must be Swiss because the quality is the best and you need good tweezers to work.
JC
2 minutes ago, Douglas1701 said:
Gonna start marks videos as soon as I can..might be awhile though.
Perfect. That's just how I started and I've done many, many watches since then. Mark's videos are the best and his technique is superb.
JC
Edited by noirrac1j
20 hours ago, Douglas1701 said:
Gonna start marks videos as soon as I can..might be awhile though. Ive been making some of my tools to speed up the process. So far i made a balance tool and i should finish the oiler station tomorrow or the next day.
That is a NICE balance tack...much nicer than a metal one.
J
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
