I have a Raymond Weil Amadeus 200 Automatic #7701 and a case screw came off the back. How can I find what size I need to order a new one?
Presumably there's more than 1 screw in the case back. If you can take out a second screw and get the measurements, then it should be possible to order a replacement for the missing one - which I assume has been lost.
Alternatively, you may want to check with a supplier or consult a maintenance chart from the manufacturer if available. Either way the part number for the screw in question may be found and ordered since you have all the information (caliber and maker).
