I recently acquired a CWC general service watch dated 1982. The watch starts and stops and I was wondering if anyone can help with the details of the movement?
The movement is a ESA 536 121 and I'm told the company was bought over by ETA and they supplied an equivalent movement for a while.
I would appreciate some help?
Many Thanks
Jim
    • Yeah I figured that one out when I googled and realized that my spindle is actually from Horia. It's smooth with no screwable cap.
