Hello!
I have a small problem with my DZ-7127 watch. It has 4 time zones and I have problem with my Time 4, it is not working, but I can set it up. Is it a problem with batery or movement problem?
Attēlu rezultāti vaicājumam “dz7127”
33 minutes ago, szbalogh said:
All dials using the same battery. So it can be a movement or contact problem.
So what should I do now? Should I carry to service or try to check it myself?
My take on it: Take it to service otherwise the warranty if any left might be void and if none left and you are not used to work on those watches, it may cost more to set it right again.
It all depends on what your goal is in the end: keep it or thrash it, independently of the outcome from tinkering with it. I hope this helps although a simple opinion.
17 minutes ago, szbalogh said:
I dont know this brand. Do You have a guarantee for it? Or go with it to the next watchmaker for a quick check.
nope, I don't have guarantee, I don't have box anymore :( I think I'll go to the specialist who can check this problem. :)
