Well in the back of one of my draws,i Found a slim sekonda  pocket watch, Reketa 2209.
Not too sure why I decided to fix it up,other than the fact that it wasn't working.
Needed a mainspring or so I thought, hmmm teeth missing on the barrel, fixed that and then I found that the second wheel also had teeth missing.
When I tried to get the second wheel  I thought iwas going mad, no 2nd wheel listed, turns out it's listed as a intermediate wheel or a transmission wheel.
Well I got it working now, it's not one I would normally do but, well a  change is as good as a rest.
I had a look on the internet to see what was said about the movement , turns out that people don't like working on it because it has five wheels
Under the plate, what a lot of rubbish, I managed it after 2 pints of Stella, and it's running like a dream.
I thought I have a 1/2 decent picture of the dial but I can't find one, but to look at the dial it looks like any other sekonda watch.
    • I suppose? If it worked before and it doesn't work now I guess the question would be why does it not work now? That would come back to if you did not have the chronograph module on will it work or is the chronograph module sucking too much power out of the watch basically 99 usually when they go bad you can hold on the tube part and usually just spin the wheel because it has zero holding at all so usually when they go bad they go bad very bad. You should build hotel when you set the watch as to whether it seems to have any friction or not. I'm just wondering if the chronograph module is the problem.
