Want To Learn About Oil
Can anyone please explain  the oils used, Is the different numbers for viscosity? maybe a good table will help with witch oils to use on witch parts and WHY? Is there any cheaper alternatives out there you can get about everywhere? Just curious. What will be a good starter pack to get , maybe something on E bay.... 1 ml will probably last me a lifetime.
Mark, I just joined this site and I am super excited about finding it. I left you a post on one of your you tube videos (Dave Matthews) about how great your videos are and how much I have learned from them. I'm retired and this is such a great hobby for me that takes up some time and keeps me out of trouble, at least until Happy Hour! Thanks Mark!
Thanks Matthd - stick around and be part of the community :)
There was one part that made me smile "It is good practice to clean oil pots and replenish with fresh oil every week"
The Author must be well off as Moebius Synt-a-lube 9010 for instance is at least a tenner for a couple of mil.
Vic
No wonder the vultures were circling around my roof all these days! :notfair:
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
