Hi all, as title, I see many people removing the bezel with knifes of all kind,
but how can I remove the bezel without scratching the watch case or the bezel itself?
Thanks
Hi. My experience has been to use a poly bag and use a thin blade like on a victorinox pocket knife. It's then all in the action. I find that if you raise and lower the knife ever so slightly (lengthwise) as you insert the blade it will "walk" off easier. Just be careful with the blade. The "walking" action reduces the amount of force needed to insert the sharp part of the blade into the crevice.
+1 horsetrailer.  I usually put masking tape (or blue painting tape) across the lugs and around the bezel at both 12 and 6.  I can then slide the blade between the bezel and case and "walk" it up, going from one side to the other, with minimal risk of damage to either., and Yes, I use a medium size Victorinox Army knife (blade), Officier Suisse.
