Dremel lathe
szbalogh
Some of You asked about my Dremel "lathe". I will post my works here with this fine tool :)
To use the Dremel as a lathe please make sure that the bearings are in perfect condition! In addition, care must be taken no to push the tool to hard on the working piece, since the shaft is to long and thin. The tool can blunted ot the working piece can break or bend. Moreover, use only the low speed stage! The manual say it is around 15000 pm for my Dremel but I am sure its a way slower.
Here, i am turning a stem for an EB1197 movement:
This was my first documented try, see this video for a much better pice for HMT watch:
Today i got one crown for it so continued work on the EB1197 stem.
Thread was cut also on the Dremel holding (and pushing) the die with 3 fingers and turning the collet with my other hand:
The Dremel is just tied with wire to a piece of iron beam. Between them are two wood pieces (one at the front and one at the end of the Dremel) with a half-circle cut to fit the two support points. Notice my adjustable T-rest! :)
Here i had to make a longer thread and shorten the length:
Just a bit more to cut down:
Using a set of collets You can see in the upper left corner. They are coming from an 8 pieces set ranging from 1 to 3.2 mm as i remember. Just search for "Dremel collet" on e-bay!
You have to check the Dremel shaft diameter since there are more available.
Just fits in the 1.8mm collet, the thread is tap7 (120 or M1.2x0.25).
It is important to note that the delicate front part has to made in one run, since the work piece wont be true after removing and putting back in the collet. But to cut down the length it does not matter.
The length is perfect now, lets glue the crown and the stem together:
And of course it is working flawless :)
Ready to go:
Next time i will make a replacement dial feet holding screw for my Roskopf pocket watch.
Edited by szbalogh
Thank You Bobm12! Also will make a simple ER20 system lathe in the near future. With that i have much more possibilities. Like turning bigger parts for example crowns or staking set rods. I am half way to make a little "two center" lathe for pinion polishing. Stay tuned! ;)
Excellent SZ! Can I ask, what do you use and/or how do you make the tools to cut on the dremel lathe? I would assume they have to be of a certain shape and with quite and edge? Forgive my ignorance about lathes!
Cheers,
Bob
1 minute ago, bobm12 said:
Bob
The big square tool on in the video is a 3mm diameter HSS Co10 rod. Sadly i couldt find any square one. Hardness is around 70 HRC.
The small tool is a "Vinyl cutting Roland blade", These are tungsten carbide tips, excellent for hardened steel, but have to work slower with it since it breaks easy. Hardness is around 90 HRC.
http://www.ebay.com/itm/5-Pcs-30-45-60-Roland-Blades-Cricut-Cutting-Plotter-Vinyl-Cutter-Offset-Gcc-/331442278668?var=540617452215&_trksid=p2056016.m2516.l5255
The tip is not good for turning, it has to be shaped. I use this diamond disks for it:
http://www.ebay.com/itm/Hot-5-PCS-22mm-Emery-Diamond-cutting-blades-Drill-Bit-1-Mandrel-for-Dremel-NEW-/272150698231?&_trksid=p2056016.m2516.l5255
Using this collet for both tools, also excellent for screwhead polishing...
http://www.ebay.com/itm/DOUBLE-END-PIN-VISE-TONG-STEEL-WITH-2-REVERSIABLE-COLLETS-2450167-/272212383988?&_trksid=p2056016.m2516.l5255
Also have a 3mm diameter tungsten carbide rod, but didnt used yet. I will replace the HSS tool with it.
http://www.ebay.com/itm/3-12mm-K20-Tungsten-Carbide-100mm-Rod-Boring-Bar-Lathe-CNC-TOOL-MAKER-Endmill-AU-/121475845355?var=420413595861&_trksid=p2056016.m2516.l5255
Today i needed to make one dial feet holding screw for the Roskopf to try on the new domed glass a grinded. Started from a 3mm nail.
M1.2 thread since the previous screw (M0.9) was broken and had to push out. Roughly shaped upper part.
Nut cutting with my new "special file" :) an old broken pocket knife.
The new one on the right.
And finally i could put it all together after a bit dial feet adjustment.
    • Learned a new thing today! 🤓 Looked this up and found this informative document: Watkins-MainspringGauges.pdf
    • Correct one dip is expensive when the chemical is purchased as " one dip " which is why it is mostly reserved for these two small parts as far as information tells us it is mostly tetrachloroethylene. I use it bought as perchloroethyl used in dry cleaning processes, i cant say I'm overimpressed with it though it appears to me to be shellac safe. What may be a better solution for hairsprings is a high lab grade of pure benzine.  IPA is mostly used as a rinse and water displacer and yes it does have the potential to dissolve shellac, personally i would not buy anything that has significant water dilution so 99.9% IPA is the way to go. And lastly the part you are cleaning dictates your choice of cleaning brush, delicate parts like a hairspring requires the finest artist's brush you can find. Plates and bridges can take a little more scrubbing, but always check to make sure the surface is being unharmed. And dont forget a stick of tip benzine soaked correctly shaped pegwood is your mate set up for cleaning dirty jewels and removing stubborn dried up lubrication.
    • Den / Dennison is a unit measurement of size this is actually a mainspring gauge . I haven't heard of a pivot been measured in Dennison before.  Though the small thickness gauge is  usually supplied with a Jacot tool and is more accurately known as a pivot destroyer.
    • Could it be an abbreviation for Denier? "Denier (/ˈdɛniər/) or den (abbreviated D), a unit of measure for the linear mass density of fibers, is the mass in grams per 9,000 metres of the fiber. The denier is based on a natural reference: a single strand of silk is approximately one denier; a 9,000-metre strand of silk weighs about one gram." The pivot gauge looks interesting, however I wouldn't trust myself to drive a pivot into a wedge incase it jams and gets damaged/snaps trying to get it free. More a comment on my ability and incompetence than the quality or design of the tool 🤣
