Warning wheel pin location
Try laying it dial down and see what happens . -
As far as I discovered, it only stops on the wrist. I had it laying on the bench for days without stopping (winded it every morning). I will look into the escapement when I get it back on the bench. Thanks for the help so far I appreciate it a lot.
Ooh, I have some of that somewhere too, thanks. I'm thinking attaching to my crystal press might be a safer idea than using a drill press, assuming its too tricky to do by hand/without leverage... less margin for error there you'd think...
How would you tell a SUDDEN STOP apart from GRINDING TO A STOP ? Does your watch stop only when on wrist, or on bench too? Heavy lock combined with excessive torque supplied, damaged pallets jewel or escape teeth. And in your case the suspect to apprehend is escape teeth. Examine both parts with high maginfication. Regs
First question would be could you get a replacement if it snapped? Yes you should be able to straighten it but need to be careful. I've found the best way is with a long piece of tube having a similar I/D to the O/D of the pivot.
