9020 or HP500? Which would I get the most use out of?
Welcome to the WRT forum. Both pieces are worth TLC, they don't make them like these anymore, so you are looking at a limited available quantity. I suggest working on them when you have acquired good dexterity and experience. Chinese keep making same chunk= junk and love to see you break them, so to sell you another one, the fact that they don't sell spare parts supports the point of my arguement. If you are buying now, why not buy two Swiss scraps of the SAME CALIBER in need of repair, such that a good running one can be made out of the two, plus, you will have your own spare parts inventory, well sorta. Keep us posted when choosing scraps and ask questions, no $ charge for advice. No shortage of help and advice here, we'll work with you till your rebuild one ticks happy and accurate. Regs
Hello welcome to the forum. I have added a couple of documents you may find worth reading TZIllustratedGlossary.pdf TM 9-1575.pdf -
Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!). So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
