Luminox 7050
By LittleWatchShop · Posted
From our very own master. And here is a more complete tutorial. -
Thanks...Any guidance you can provide would be helpful. I just don't know where to bend / apply force. I'm sure @nevenbekriev is just shaking his head here. 😁 I do have a piece of good news, which is that another one of my projects is actually moving forward (Hamilton 974 Special, Double roller). Just got that one up and running.
Seldom do I have to remove pallet stones. But maybe an experiment with the bad stone rather than pulling it out what happens if you? I'm trying to figure out how to word this. Often times if pressure is put either on the top or the bottom of the stone typically at the end the stone will become angled of course either up or down. So rather than pulling the stone out what happens if you push on it were at angles itself to its almost this is really worded very peculiar but I'm proposing instead of pulling you pushed down on it and get it to rotate and then you should build I have basically less side contact on the stone that makes any sense at all. It is actually quite easy on full plates for instance when you're putting them together to overlap the escape wheel to in the pallet fork and end up with the stone at some weird angle and it's as easy to do that it might be easier to get the stone out that way than by trying the political out where yes they seem to be quite tight even without the shellac
What part are you trying to make?
