The spring keeps the threads of the crown and crown tube separated while you are winding the watch. It will work without, but the risk of the thread engaging, or worse, cross-threading, is high. The split stem needs to give the crown enough end float to disengage from the thread, but leave the main part of the stem and the keyless works in the winding position.
4 hours ago, Michalzeszen said:
And is there a possibility to convert it to a springless system by replacing it with a standard split stem model?
A standard split stem will probably not have the end-float you need. It has no advantages over a one-piece stem in this application, because when you unscrew the crown the stem will be drawn out and the keyless works will move from the winding position to the setting position.
The conventional reason for having a split stem is to enable removal of the movement when the stem release is not accessible, e.g. when you have an integrated case back. As has already been pointed out, you don't need this feature.
Hopefully your watchmaker pal will get the screw-down feature to work in harmony with the "special" split stem he has in stock. If not, ask him to remove the screw-down feature ( remove the thread from the crown and / or case) and fit a conventional stem.
Edited by Klassiker
Not while maintaining the screw down crown as I mentioned above.
12 hours ago, AndyGSi said:
If they want to use the original screw down crown then yes it's necessary, otherwise there's no play from the winding position to screw it down
Unfortunately, I couldn't source the correct part from the old folks. I did find this:
https://lobtime.com/shop/ols/products/screw-down-crown-kit-set-of-5-for-titus-calypsomatic-diver-watch-technos-skydiver-fayt
It is much more than I should pay for a set, but it is interesting to see that someone is producing it to keep up with a somewhat rare demand.
41 minutes ago, Nucejoe said:
 Can't you solder male and female parts of the stem together, it'll do as a one piece stem.
So how would that give you the end play from the screw down crown?
That is a bit on the pricey side.
I wonder if it's possible to drill the second hole yourself in a normal split stem?
Didn't think of that.
I don't know the details of their production set-up, but for small batch production 50 USD seems not unreasonable for the set. The photos are excellent. The parts appear to be very well made. It should be clear now how they all work together.
It maybe worth a message to them to see if they'd just supply the part you need.
You'll also need to confirm the thread size to check it matches your crown.
Yes, I'm looking at this option. I have a good friend from childhood who happens to be a goldsmith, and he would certainly be able to tackle the second hole to my specifications. I usually avoid this path because, since he deals with gold pieces, every time he stops to help me with "frugal" parts, he is objectively losing money.
I agree with you. Even though I couldn't justify paying this much for the set (they only sell the whole set or the sole case tube), I understand the price tag.
The trouble with this particular stem set is that the most common use case for it is the Technos Skydiver, a watch whose price certainly justifies 220 USD for a brand-new stem set.
I have messaged them only on the surface, without specifying my needs. They already stated that they don't sell the single female part, only the full set.
What I still don't get is the need for a second hole. Is it supposed to be some sort of regulation, meaning that I can fit the head of the male part in any of the two holes to adjust the pressure of the spring? Does this mean that a single-hole female part has a chance to work with my setup? I'll later test this hypothesis while continuing the assembly of the movement.
Some photos are attached. Can you judge this bracelet? It was dirt cheap (4 USD), genuine leather, wife's choice.
I have just realized my dial is upside down. lol
As you've shown the crown and stem is the winding position.
You then need the second hole to be able to push the crown further towards the case to screw it down.
Ah so it is an active system. Both holes are in use (hehehe).
Interesting.
I'm sure several of you will have a similar story: the nanny let my 1.8-year-old inside the office. He climbed my chair and hand-slapped my workstation, sending the half-disassembled watch and all its pieces flying.
My floor is a wooden patterned floor with several small grooves, and it was hell. I managed to find everything, but two gears didn't survive. A donor movement is on its way.
  • Sad 1
