Hi all,
I'm in the position to take over a Boley lathe. It's 8mm with a cross-slide and faceplate I wanted. Apart from making balance staffs and winding stems, an important goal would be repivotting and drilling out worn pivot holes to rebush (oval ones making round again).
There is however no tailstock included with drillchuck or even just one with simple collets. What are my options? As it's also no WW, finding compatible tailstock will be next to impossible (and then there is the problem with alignment).
I know there are people doing it freehand but as a novice with not to steady hands (understatement) this seems extremely difficult.
It would be used for wristwatches and clocks.
Kind regards
Edited by Jjver
Added image
  On 4/4/2025 at 10:09 PM, Jjver said:
Hi all,
Kind regards
Expand
You have a tailstock there and that is the basic thing you need for the type of drilling you want to do. Not having a drillchuck or collet chuck is no problem. Previously there have been several options mentioned. Check out this thread for instance:
https://www.watchrepairtalk.com/topic/31637-tailstock-runner-specs-for-peerless-2/?do=findComment&comment=271873
Edited by caseback
That is a nice lathe with a really good set of attachments!
You can use a hand guided runner through the existing tailstock.
There are various collet adapters for runners that take a taper insert, and there are also runners of different sizes with mounted chucks on ebay.
https://www.ebay.co.uk/itm/266810651953
https://www.ebay.co.uk/itm/405687866138
It should be reasonably easy (if not quick) to find a drilling tailstock on ebay - Original Boley parts for the same type bed do appear regularly.
There are two fixed tailstocks on at present, but not a drilling one. I'd set up a search so you get notified when one is listed.
(And from experience, WW ones are far less likely to be interchangeable! I've been trying to find matching WW parts for months; I have multiples headstocks, tailstocks & beds - and no combination that fits to make a complete lathe!).
On a Pultra 10 8mm lathe the the drilling is done by a tapered brass collet to fit the runner with a hole in to take the drill bit with a sleeve over to squeeze the collet to grip the drill bit , as carbide drill bits have all the same size shank you would only need to make one.
Dell
This is the tailstock
Thanks for all the quick help! Glad there are options available. I'll start with the basic turning first, but good to know the next steps will be possible too.
What do you guys think a fair price would be (in Europe). Don't need exact amount, but it's an older gentleman and it's not my mission to make the deal of the century. It's possible I need to upgrade to another model in the future (I want to do clock work and milling eventually), and just don't want to make a loss then, however making a profit is not needed for me.
Expand
Personally, I would be a bit wary of asking valuations on any forum. Without sounding obtuse, something is only worth what someone is willing to pay for it and what the other party is willing to take, so I'm sure you'll have an idea of what to offer by looking on Bay what something like this has gone for in the past.
Someone might tell you that the lathe is worth £2000 and someone else might tell you £200, so you still don't have any idea what it is worth to you.
As Jon said your best bet is google it & eBay is a good sauce of price guide but some things go cheap so don’t take it as gospel, it looks to be a complete kit in good condition so something like that won’t be cheap.
Thanks both, I understand completely your reservations. I just don't always understand the differences in quality and completeness on eBay and did not want to rip of this gentleman. But I will make an honest suggestion. Thanks for all your guidance here.
Expand
Let us know how you get on, not price obviously but just if you purchase & any help with using it if you are unsure about anything
Expand
That's extremely nice. You guys will certainly hear from me again.
PS: love your Youtube channel!
    • Hello and welcome to the forum, the best path to take is to get some medium priced tools , look at Cousins UK . They are a material house and are open to all. There medium priced screwdrivers are middle of the road and wil if looked fore serve you well into the foture I have added a little reading for you to help.  TZIllustratedGlossary.pdf Watch_tools_tipps.pdf
    • After another long hiatus (while waiting for truing calipers to arrive), I’ve made some more progress. TRUING IN THE FLAT I was able to use the calipers I purchased to true the wheel in the flat. There’s still a very slight eccentricity in the round, but I’m going to leave it as is. It doesn’t wobble any more and I’m happy with that. Thanks for the tool recommendation @mbwatch. It worked well, though I must say it takes a delicate touch to get the balance between the calipers. Also, my calipers effectively have four different variations based on the orientation of the arms (2 sides, 2 orientations each). Some are more tapered than others, though to what end, I can’t quite tell. My first thought was that flipping them over yields arms that can be used for poising. They are K&D horizontal calipers, btw. OSCILLATION TEST @nevenbekriev @JohnR725 After truing the wheel in the flat, I carefully remounted the hairspring and did your oscillation test. Balance wheel mounted to balance cock, no pallet fork, rotate balance wheel 180 degrees, let it go, and time+count the oscillations. Results as follows for dial down orientation: Duration: 1m 15sec (to full stop) # of oscillations: About 125, though the amplitude of the oscillations decreased significantly, as one might expect I should redo the test in at least two other orientations…Forgot to do that. 🙂  In general, it’s safe to say this watch has a pretty low amplitude, likely for a variety of reasons. I haven’t oiled the balance jewels FWIW…I should probably do that, but I really don’t want to keep disassembling and reassembling the balance. Is it possible to oil those jewels (top and bottom) by just removing the capstones and putting in a tiny amount of oil, with balance in place? I can see how having the pivot in the jewel hole could change how capillary action works, and thus might pull more oil in than desired. However, those capillary forces will be in effect anyway once the balance is inserted. PRACTICE MOVEMENTS @JohnR725 I agree with your sentiment about using practice movements wholeheartedly, and I’ve done that to some degree. The watch I’m currently repairing is for a friend, and she was willing to have me treat it as a “learn-by-doing experience.” With that said,, I probably should have purchased a few more “beaters” before getting to something where I don’t want to muck things up. I’ve still got a couple of those on the bench that I used as donors, and I’ll try to rehabilitate them.
    • Hi, this is the first place I found when looking for advice so I hope someone could advise me.  Im completely new to touching watches but I’ve always wondered how they work.  I’ve bought a cheap movement, an ETA replica to take apart and rebuild.  Im thinking I’ll need some screwdrivers, tweezers, movement holder and a loop? My goal is just to have a go first and see if I enjoy it enough before buying more tools.  Do I buy cheap tools for now and get better quality tools later if I enjoy it like I think I will? or will the cheap tools be a pain and take some of the fun out of it?  With quality tools being relatively expensive I’m unsure what to buy.    Any advice would be greatly appreciated!
    • Yeah I have seen 44-56 documented for Elgin 18 size elsewhere. I have the style of gauge that's like a set of feeler gauges and I never noticed before today it is faintly stamped "Elgin". Pictured is the way I have been measuring. I am going to go to a larger jewel than the 42 that had been in there. I recently won an auction on a big set of Fitrite jewels all in the little bottles, to discover that the what's actually in the bottles bears no relation to the chart of sizes printed on the box. In most cases it seems to be all mixed so in fact I have about 24 little bottles and thousands of assorted jewels of all diameters and lengths, which is better than nothing. But since I don't have a micrometer with a table, measuring for the exact diameter will be a big job. Instead I will test a lot of them in the fork slot the same way I measure with the gauge. But this is still the next thing. I have to get the escapement to unlock first.
    • it would be nice to have the exact model of the watch the or a picture so we can see exactly what you're talking about. this is because the definition of Swiss watch could be a variety of things and it be helpful if we could see exactly the watch your dealing with then in professional watch repair at least some professionals they do pre-cleaned watches. In other words the hands and dial come off and the entire movement assembled goes through a cleaning machine sometimes I think a shorter bath perhaps so everything is nice and clean for disassembly makes it easier to look for problems. Then other professionals don't like pre-cleaning because it basically obliterates the scene of the crime. Especially when dealing with vintage watches where you're looking for metal filings and problems that may visually go away with cleaning. Then usually super sticky lubrication isn't really a problem for disassembly and typically shouldn't be a problem on a pallet fork bridge because there shouldn't be any lubrication on the bridge at all as you typically do not oil the pallet fork pivots.
