Replacing Jewel In Modern Watch , Eta Bridge Etc
Ah ok thanks, that maybe answers that one then, Cheers fellas 👍 -
From what I've read it is more prone to shatter and exposed edges can chip. But my Breitling has received some hard hits to the sapphire - e.g. when I've accidentally hit it against the corner of a desk, and no visible damage done.
