JLC 929/3 Master Geographic (base JLC 889/2, IWC 3253, AP 2124)
I found a motor that is 3/4 hp and another that is 1.2hp. They come with speed controller. So I don’t think I would need a wiring diagram. But I sure appreciate you offering your help! Do you think 1.2 hp would be too much for a watchmaker’s lathe?
At the moment I have neither EDTA solution nor Evaporust, so I tried with a citric acid solution. This gave satisfying results for most of the parts, except for the ones that are really heavily corroded. I will see whether I can acquire one EDTA or Evaporust and try that next.
