Hello
I've never moded a watch before so I'm not sure what order I'm to assemble it nor what gaskets I should be using.
I believe the steps are:
1 - Case & chapter ring - does this usually have a gasket?
2 - Chrystal - does this usually have a gasket?
3 - Bezel  & Bezel insert
4 - Bezel click spring & assembled bezel from step 3. - does this usually have a gasket?
5 - Movement, dial & hands.
6 - Case movement and install stem and crown.
7 - Install case back - I imagine there is a gasket with this?
8 - Install watch strap.
9 - Admire
Thanks in advance for any help that can be provided.
Gasket/case wise often many come with the caseback, gaskets and crystal in place and assembled. Same with chapter ring - it's worth seeing if you can find the config you want preassembled.
Edited by tIB
