I'd like to get a watchmaker's lathe, but there's a mind boggling array of lathes, collets, accessories, etc. out there to wrap my head around.  I know a watchmaker with several lathes and he has offered to sell me this Lorch 8mm lathe plus a motor for $1200.  I'm just trying to get some feedback on if this would be a good set to start with and for that price.
  • Two headstocks, one with a faceplate
  • Collets up to 4.2mm.  He thinks he has a spare 5mm collet to add to the mix.
  • X-Y cross slide
  • Partial milling attachment
  • Motor
He'll throw in some other bits and pieces.
I do realize that there are other things that I will be needing to go along with this (belts, speed controller, gravers, etc), just to get going with it.
The slide is for use with the headstock on the right, and may also have reversed threads on the advance (some Lorch do, some don't). I don't think it can be switched for use with the headstock on the left. For me that would be a no-go. As you are in the U.S., I would keep my eyes open for a WW style lathe, perferably with a collet holding tailstock. Levin, Derbyshire, and Marshall (not their Peerless line) are all very nice machines. You might find a Paulson, which was made by Boley-Leinen, also excellent, as well as Boley. Lorch made a WW style, the KD50, but they are very sought after.
What would be the issue with the advance for that particular headstock?
The seller indicated that a collet adapter could be used with the tailstock, like this one that holds ER11 collets.  Though it would need to have a 7mm shaft he said.
The lathe can be situated with the head to the right or the left. Convention is to have it to the left; but that slide is built to use with it to the right. If you put the head to the left, the crank on the left side of the slide will be crashing into it.
Like this slide. Works on my 8mm Lorch, but not on my 6mm Wolf Jahn..
Edited by caseback
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
