Hi, guys
Are there any Timex gurus out there? I'm looking for a winging stem for a Timex Indiglow WR30 and as this watch lacks any reference numbers, I'm lost at sea. The only visible number I can see is on the case back, which is 05. I thought I might be able to put a stem extender on it but then realized it's not going to work as the stem is broken off flush at the crown so if you put the two broken bits together it's obvious there's not going to be enough real estate for the end of the extender.
It would be nice to get the correct part, but if not, then plan "B" would be to use a generic crown that doesn't have the extended tube with the seal on it, It's not ideal but that may work 🤔  From the picture if anybody can identify the part number for the stem I would be grateful.
Okay, my mistake I did eventually see some numbers on the movement but they meant nothing to me, and when I searched any of the numbers I came up with nothing most probably because I don't know the movement manufacturer. Anyway, in no particular order, the numbers on the movement are B43, 15 on its own, and 11 with an M above it
Edited by Zedster
    • Righty ho, I re-serviced the chrono module and got a reasonable result with minimal loss of amplitude when not running the chrono and about 30 degrees loss when running. Great. The problem is now that the chrono (and movement) stops running after about a minute or so, a tap on the watch starts it running again. No issues with the movement running when the chrono is stopped. Going to service it yet again, obviously some residual issues with friction in the chrono module (Very frustrating - I wish there was some way of testing it as I go!) I also seem to have a problem with the cannon pinion where the movement is running continuously (with the chrono stopped) but it's losing significant time / stopping. This is one of those two piece ETA style with a driving wheel pressed over the cannon pinion, obviously arranged for driving the chrono module. I had no issues with this prior to service and just added a small amount of grease between the driving wheel and the centre cannon pinion as the technical guide required. What's the best way of tightening these up? I would like to replace it but I guess this is going to be hard to find as it is dedicated to the DD chrono movement.
    • He uses the micrometer cap, but he leaves the spring out (you can see that in the video). If you leave the spring in, the spindle will move up as well (as shown by @Knebo).
    • Seems like he doesn't have the micrometer cap  attached to the spindle so he can only push down but cannot pull up? If the cap screws into the spindle I guess you don't need the spring? I only have a "normal" Seitz so I really have no idea.
    • Do you have a part number for the bearing shim lock tool?
    • Yes in my opinion the 3/4HP is plenty but it’s your decision & yes it does come with speed control but foot operation so my reason for changing to potentiometer was because my leg shakes so it was like me revving the lathe & anyway I prefer to set the speed. I & a few others that I recommended the motor to run a Pultra 10mm lathe so if you have a 6 or 8mm B & L then it will be plenty, if you have seen any of my videos you will have seen that when using a graver I run quite slow without any problems. Dell
