I have a Rolex model 1400 lys watch worn to where the stem will fall out.  What are your techniques for building these areas up?  I do have a jeweler friend with a laser welder.
IMG_2813.thumb.jpeg.b1d9436730fe74fedbdf610d61be4b5f.jpegIMG_2811.thumb.jpeg.d9bd09b672117e24788afb98f7622bba.jpegIMG_2814.thumb.jpeg.15b281e9ca9af1e9a9388223fcaf6615.jpeg
Edited by GeorgeC
Sounds like you need a new stem and/or setting lever probably the easiest way to go is to order a replacement of whichever (or both) of these which is the problem.
Can you close picture the stem and setting lever by itself to see if either is damaged.
