Hi everyone,
I found this old Waltham watch to service it, but I don’t know how to open it. I see someone tried to open it from the side and messed up the watch a bit. I’d like to be smarter than that with help from you wise ones.
Would anyone know if this is a pop crown kind of watch or a weird screw back? Any help is welcome.
I have a case back opening knife and tried to pop it where someone already tried because that is the only part that seems to have a notch. It was so hard that I thought I would end up scratching it more. It doesn’t seem to have any other notch or holes for screwing it off. I’m stuck on this one 🥲
In the first photo, it looks like there may be a knife groove just under the right strap lug?
Try a bit of penetrating oil around back joint, in case there is some internal corrosion??
Crazy thought, check to see if it has a split stem. There's a type of case that LOOKS like a pop off back, but isn't. Three piece case to where you'd want to press the crystal down through the bezel/lug ring. I've never seen a Waltham with that style case, but it's a thing.
Alternatively, someone might have glued the case back on for some reason or another. Try giving it a little heat maybe?
