Hi,
I was given this yesterday while helping someone move stuff around for a house restoration.
The case is very poor but complete with a mineral glass crystal. There were no case screws, only the hour hand still present and the dial is wrecked - I'm guessing someone may have tried to force it off without loosening the foot screws, as the "craters" are over the dial feet.
The behaviour of the movement  is very strange! The balance wheel was very free and would oscillate for quite a while, with the escape wheel moving back & forth slightly as the pallet fork nudged it, but nothing else turning despite it being fully wound!
I've never seen any movement behave like this, so it got me really puzzled. I tried oiling the pivots at both sides in place, with no effect at all.
I then did a quick partial strip down. I though the pivot may have been bent on the wheel that carries the second hand. That looks straight - but the entire staff & pinion look black! When I removed them there was lump of something that looked charred on the plate?
Partially re-assembled & lubricated again, it started trying to run as soon as I put about half a turn on the ratchet wheel, but only just enough for the escape wheel to turn.  No different with around a half wind.
I tried a bit of 9010 on the pallet stone faces and that brought the amplitude up quite a bit - until it stopped dead.. I kept restarting it, it was barely ticking for a while then the amplitude came back up a bit, but only around half the best it was earlier.
It's very odd. I initially thought the black pinion was rust, but with the wheel out it looks more like a very deep blue, as if it had been heated?
Some of what's happened looks very amateurish, like the dial damage and blobs of mismatched paint - but I wonder if the pivot was bent at the seconds hand end and someone has straightened and re-tempered it?? The problem seems to be around that wheel & its pivots.
I don't expect it to run well without a full stripdown & clean, but with the movement problems and really needing a new case, I don't know if it will ever be anything more than a curiosity.
Hi, this is steel 'gun metal' case, so it is not a problem to grind the back and polish it, then give the case to someone who will be able to make it blackened (oxidated) again. This is a chemical process where usually the seel is boiled in NaOH at 150-60 degr celsius for several hours.
The movement is not a problem to repair, but it is a 7 jewels movement, so check the bearing holes for oval wear that must be restored. Yes, the second hand pivot has been bent and somebody has heat the entire pinion of the wheel, thus tempering it to be able to straighten the pivot without breaking it. Heating the entire pinion is a mistake, bit what is done is done. Check if the table of the wheel has gone soft as result of the heating, and if it needs truing. You will need to burnish the both pivots of the wheel and restore the bearings (and bring them to the correct places, as they can be shifted - signs of hole closing are seen on the bridge) to restore the normal function of the train.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
    • I've repaired a few of these, having some success with stripping and cleaning the mechanism.  They are so cheap though, its hardly worth the effort in many cases.
    • Get well soon Old Hippy, torn muscles.,  not good
    • Id love to see how he has the output shaft mounted to this setup, as I have the same rotary stage and stepper in my build.
    • If you see at least one thread protruding, or even a half, then you may have a chance using this "tool", but don't squeeze hard. Lot's of patience, and if you notice any signs of loctite or other adhesives, then apply several drops of acetone on top of broken stem. Use heat (hair dryer) also. You should be able gradually turn it counterclockwise, just like i did on this broken Timex stem, which was glued with something like nail hardener. Then you can use an extender to save your broken stem. https://m.media-amazon.com/images/I/513DVvkfW5L.__AC_SX300_SY300_QL70_ML2_.jpg   You can also try cutting a small grove / slot on top of the broken stem to use 0.7mm flat screwdriver.   Depending on the Crown material and Stem material, you can try dissolving the stem.
