1 hour ago, mikepilk said:
I only watched the start, but he's out on magnification by a factor of 10. It's 7X to 45X, not 450X
Oh weird! I saw this video months ago and made this exact comment on it. Or at least I thought I did, because I don't see it.
I noted that at 450x you'd be able to see individual blood cells.
I would guess a simple mistake, I took it he meant 45, any thoughts on the scope?
2 hours ago, Chief said:
I just watched this yesterday! Making me jealous! I'm still using a loupe wedged in my eye socket 🤣 definitely putting one of these on my Christmas list
Do, write a nice letter to Santa. I do all disassembly and assembly under the microscope. I consider it a necessity.
How do you find the working distance from microscope lens to movement? Is it comfortable enough to get tools in?
More than enough. Here's mine at the height I work at. I think the working distance with the included 0.5x Barlow lens is about 9".
So yes, that halves the magnification. The full story is the objective lens goes from 0.7x to 4.5x. The eyepieces are 10x, giving you the advertised magnification of 7x-45x.
However the working distance is unacceptably short, so it comes with an 0.5x Barlow lens, reducing the magnification range to 3.5x-22.5x, but giving you a good working distance.
What I did was buy a pair of Extreme Widefield 20x Eyepieces for when I need more magnification. You keep your high working distance, but get your 45x magnification back, at the cost of some width of field.
I agree, game changer. I watched Alex's video as well. Another thing to consider is the adjustability of chair to bench and the head of the scope so that at max height is not above your eye level. I got the trinocular port for the camera but did not get a good enough camera and have not figured out how to run it though my laptop to make videos or just take stills through the scope, yet.20231029_0947003.thumb.jpg.729e431e723040e3847dced6ffb209ad.jpg
Get a couple of elbow pads, these are inexpensive and have sticky back, but I don't have them stuck down and can move them around.
Chair height is not usually an issue unless you under 5' 2" lol.  The thing to watch out for is a draw in your bench above your knees.
Whats your field of view with these please msb ?
At the lowest magnification, I can just get all of a normal wristwatch size movement in field. For some things it's too much magnification, but the nice thing about the eyepieces is they only take seconds to swap in and out.
I'm genuinely surprised I've never read about anyone else doing it, to be honest.
I think maybe we're all a bit dim @ManSkirtBrew 🤣
99% of the time I'm working with the 0.5X Barlow, so mags from 3.5X to 22.5X. When I need a close up of a pivot or jewel, I take the Barlow out, and even put in the 2X Barlow, but it's a nuisance.
So like you, I had that D'oh moment, why don't I just use 20X eyepieces (WF20X/10). They take seconds to change, and you keep the working distance. The only downsides are lower field of view, and less brightness.
Does anyone use the x5 eyepieces,  when i use them on my different amscope , the magnification changes to x5 but the field of view remains exactly the same as the x10, so nothing gained. The optical lenses can't be swapped out or at least they are not available as far as i know.
    • My thinking is yes it is better if you were to choose this or a tg, although the tg can do more . This way the watch is adjusted specifically to you and your routine. As an example i restored an old Smiths pin pallet watch ( typically an inaccurate movement ) around 3 months ago. Adjusted through 5 positions on a tg initially proved ok but not precise over time.  Having then re- regulated the movement after each week of wearing over a period of 6 weeks brought the timekeeping in much closer, now within 1 minute/week
    • Hi,   was just debating whether to repair a Timex -- so here I am!
    • Hi everyone, I am Michael and I am completely new to the watch making world. After buying a mechanical watch a couple of years ago and realizing that the time keeping degraded significantly recently...I started digging and got fascinated by the topic!  I disassembled the watch with the Miyota 821a...and this gave the initial spark. Right now, the movement is still disassembled...and I am trying on a different movement my cleaning and lubrication before finalizing this project 😁 I am hoping to find help when I get lost and ask maybe some stupid questions - sorry for that in advance 😉 All the best, Michael
    • As it is your watch the answer is yes! When regulating a watch for someone else there's no way we can tell in what environment the watch is used and how often the wearer of the watch will wind it. In that situation, a timing machine is a handy tool to get close to something that likely will be acceptable. As indicated by @tomh207 and @clockboy a timing machine is a great way to quickly determine the health of the movement. If you are considering a Weishi I'd recommend the 1900 model over the 1000 model as the 1900 has a gain setting. These machines work well but aren't foolproof. If you want something more advanced I'd recommend the PCTM software from @praezis.
    • Hi guys, I am completely new to watch making and currently I am iterating on my cleaning process to get it right. My current process is a 3 step cleaning routine in an ultrasonic cleaner and drying afterwards in a food dehydrator at 45°C. 10min wash with Elma Red 1:9 at 58°C 5min rinse in distilled water 2min rinse in IPA 99% 10min drying in a food dehydrator at 45°C I have an old ETA 2842 which I use to test the process and the cleaning in general works pretty good...but I found one strange thing during one run I did yesterday. After the 10min wash cycle in Elma Red 1:9, the bright silver balance shock jewel metal housing colored black. Do you have an idea what happened here? Thanks, best regards Michael
