What? Me? A tool junkie?
Cheers both - Wife thinks I'm mad ironing clocks!
By watchweasol · Posted
Looking good Michael. A grand job. -
By rjenkinsgb · Posted
I'd try to cut one from thin brass sheet? That's readily available and easy to work. Cut a strip with the length just less than the original part circumference, wide enough to include the tabs, then use a nibbler to cut the excess away between the tab positions. (This type of thing, if you've not seen them) https://www.ebay.co.uk/itm/256437891452 -
Hello and welcome from Leeds. No such thing as a stupid question. Find something to practice on before starting the Vertex. -
I'm looking for the movement spacer ring for a Vertex 1944 military 'dirty dozen'. Ideally, I'd like to buy an original, although that may prove difficult. So, anyone with anything similar or just the correct sizings, would suffice for now. Alternatively, is there anyone that may be able to machine one (preffered) ? Or maybe even the dreaded 3D printing ?
