Seitz jeweling tool manual
It just seems like it won’t work all the time but only sometimes. It is the post version… I now serviced the complete movement and made it run really good now. It ran for over a week without stopping (of cause I wound it up every morning) and it was keeping time and not stopping. I gave it back to my dad, and after one hour of wearing it, it stopped again.. I found some hair around some of the posts on the wheels and I thought it was where the issue was.. I’ve got a spare movement for parts, and my thoughts is that my next move would be to change all the wheels.. but I’m kinda lost
Project: 1, side project count: 3 next side project will likely be a work holding idea to get some piece just so. This stuff is a never ending source of things to do and entertain us Tom
By nevenbekriev · Posted
Please do not file nothing. I have no time this days and am able to write here only in midnight time, so please wait... -
The project is still alive. The parts are roughed out from ground flat bar stock. But before I can move ahead I decided I needed to replace the spindle bearings of my milling machine. There was too much play on the spindle.. But after diasassembly and measuring the bearing spacers, it turned out that the difference in height was 0,189 mm. Way too much to achieve preload on non-paired bairings. So, the spacers need to be ground to get them to the same height so I can use a paired bearing set. To do that I need my surface grinder up and running and that needed a hydraulics overhaul. And that would be easier if I clean out my parts washer/de-greaser first..😀 So... this is getting to be one of those "I need to fix the machine I need to fix this machine to...." type of situation. Happy as a clam though 😃
Have a look at this discussion where I show what I use.
