Graham-White 8mm lathe
I believe that JLC are all in house high end movements, hence spare parts extortionate prices. Sorry I can’t help with the pivot repair. Tom
I expect you have at least one of each missing screw on hand so best to measure them and see if anything here matches up. https://www.cousinsuk.com/product/case-back-screws-sets-or-individual-sizes Tom
What amplitude are you seeing in each position ?
By BFernandes · Posted
Hello all. I was wondering if the irregular readings I'm having in the timegrapher is due to the mainspring needing to be replaced/serviced. What I mean by irregular readings I mean +8 sec/day on one position and -20 on another. No matter how I regulate the balance, I can't get close to 0 on several positions. -
No problem I'll have a look now, i dont remember it having a retaining ring but i could be wrong, I've not worked on it yet, its just to be a donor when i find a military Vertex. Sorry matey no movement ring in this, someone else might have one but its going to have to be in a DD case to get those sizes right.
