About a fortnight ago I got bitten by the watchmakers lathe bug. Now I am slowly adding accessories as needed. Watched a lot of videos, read every post in this section and picked up de Carle's 6th edition of "The watchmakers and model engineers lathe: A user's manual". Even though the Graham - White is not listed it is similar to WW models made by Leinen and others. Is an 8mm with an American style bed that is 303 mm or about 12 inches long, 50mm center height. Came with the 110 volt 1 Amp AC/DC motor (I think that is about a 1/6 HP) with variable speed swirch mounted on a borel stand. I van see why some might not like the stand but it makes it compact that I can pick it up and move off my bench for storage when not in use.
It was pretty dirty with quite a bit of surface rust which I was mostly able to arrest and still will likely do more cleaning with WD40 to get the last bits. Not pitting into the metal but really spotting where the nickel plating is gone. Really can see that on the tool rest which using a sanding stick cleaned up nicely.
Getting the headstock disassembled was a bit challenging as the set screw head was stripped and used an ez out style bit to get it out. Got a replacement from my machinist brother, but actually now that it is out and cleaned up an Allen wrench is working to tighten and loosen the screw.
Came only with a 24 starlett 8mm collet in the headstock and the vigor chuck in the tailstock.
The replacement belt was pretty easy - 3mm dryer transmission belt. 16 feet for $6.50! Looking around online (ebay) people have like 10 feet for $20, the only difference seems to be it is called watchmakers lathe belt!
One question on the oiling is 3 in 1 okay for the cone bearings and how many hours between adding oil to the bearings? My brother says the 3 in 1 is probably ok...
Thanks for reading this far and now for the pics! Any advice is welcome!20240128_1034142.thumb.jpg.f4896f6df7ad2fdf00e5b8060ec56365.jpg20240128_1034302.thumb.jpg.2b9c2e082d634795d2ec36c76ae5c133.jpg20240128_1035212.thumb.jpg.d1fde06de2daa0be9caee3daee2648aa.jpg20240128_1034582.thumb.jpg.15c4329b261e392d223c280b080df121.jpg20240126_1043232.thumb.jpg.9c631345cc6c6be8dfebd79705aa62fa.jpg20240128_1035332.thumb.jpg.f6f8f390b4384482bf245f16221c1316.jpg20240122_1907312.thumb.jpg.62a7b5c8ef408542b1ab5f263082831b.jpg
I would top up the oil each time you use it, turn or run the headstock so the oil is pulled into the bearings. Dont use 3 in 1 oil , bike chain yes , precision bearings no.
Looking back into de Carle,  the bed and headstock looks more similar to the Levin, Moseley and Peerless models.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
