Removal of safety roller and roller table?
The sping is not pushing directly on the cap, but is pushing against the spindle. So, even if the usual black cap is replaced with the micrometer cap, the spindle is still pushed up.
But he tells that the micrometer cap doesn't screw into the spindle. How can the spring push the spindle up if there's nothing to grip? There is a screw visible on top of the micrometer cap so should it be able to screw into the spindle? I'm feeling really dumb now. Does anyone manufacture that cap as an aftermarket item? Might be worth investing. Ok so the spindle is different, now I get it.
Sorry, I should have been a bit clearer. I have had this watch for a long time and it previously stopped due to an obstruction in the train. Never had any issues with the cannon pinion until after the service.
