Balance for a Cattin 66 movement
Hello, asking to buy something breaks the forum rules. I have edited your post. We will attempt to help you source one. -
By steve1811uk · Posted
Hi Everyone, I am looking for a winding stem sleeve as mine is broken and the crown keeps popping up into the hand setting position. Dimensions are 4.9mm diameter and 8.3mm long, I think sometimes described as being for a 16S watch. Thanks in advance, Steve. -
With anything of any size to demag i need to hold onto it to stop it sticking fast. If i put a balance or part in a container it vibrates like crazy. -
Maybe you got a badly wired one like the one I had. Can you feel the metal object vibrating when you press the red button? -
UK is 240 volt H, but i could plug into a dual volt shaver socket for a 110v comparison, i also have a variable voltage supply control. Thats prob why you experienced poor performance from your blue one.
