AS 1712/13
Hello all
Working on a wonderful watch. Bulova Caravelle which has movement AS 1712/13.
Having a great time. I've disassembled the watch with only 2 'pings', both collected, so all there. I've vidoed all the disassembly so I know where everything goes, Except ..... The Automatic winding unit is two plates press fitted. I pressed the plates and the unit separated, The internal parts were displaced and I did not see where all went.
I've looked on Rafft for the AS1712 and it shows the movement information, But there is no display of the automatic winding.
Anyone know where I can find an exploded diagram of the AS1712/3.
Thank you
Ross
  • 5 months later...
Update. Like to tell people of my activities. This one is an ongoing failure. Will not let it defeat me.
I have build and rebuilt this watch over 5 times. There appears to be no quick set facility for the day or date. I can get everything working. Wind though 12 for hours and date and day change crisply. However If I needed to move the day, say from 1st to 31st, then I need to wind it 24hrs x30 to get there. No quick set for day.
I've looked at all the Youtubers who do this watch and do exactly as them, same parts used. None missing. None demonstrate the quick set options. Everything done is the same way. At my wit's end.
I have sent for a donor movement that shows day and date on the dial.  When it arrives I will do a full photographic dissemble.
Edited by rossjackson01
Spelling, Grammar
Looking at the second video, as they check the date change 11 to 12 - it appears they wind the time back again, and the date ring kicks slightly but stays on 12?
Is the "quickset" done just by setting back and forward near midnight, to repeatedly trigger the date advance?
Other than that, it looks like the keyless works only has two positions, for winding and time.
1 hour ago, Razz said:
Try going back to 8pm (instead of 9) to initiate the quickset, I found that to work on some models.
It's not often you are wrong. But you are both right again. Inexperience rules.
Thank you for taking the time to reply and advise.
Ross.
Spelling, Grammar, more information
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
    • Is magnetism such a major problem that we (as home hobbyists) need to spend $$$ on a fancy demagnetiser? I use one of the cheap blue Chinese demagnetisers (£10 from ebay). It works, and has never failed to demagnetise a movement, or my screwdrivers. Magnetometer - who needs one?  Take a very small screw. If it sticks to the clean part, it is magnetised 🤣
    • My overall preference is to use traditional names and terms, that became my habit when i was taught joinery by old boy chippies 2 generations older than me , that had their time in the 40's. But what i often do is adjust the names and terms i use according to who I'm talking with. Sometimes i will say trainside and occasionally watchmaker's side. I try to find a balance between accommodating other folk ( there's no point speaking a foreign language to someone who doesn't understand it ) and using a name that appears to me to be more relevant as to its use or description. But using the name lever can be quite confusing,  some watches might have parts that are also levers, release levers, which in effect is what the pallet fork is, an escapement release lever.
    • Then put the case number in here https://www.cousinsuk.com/category/filter/search-seiko-case-parts and it should give you the crown
    • I come across to replace the crystal of a 7734 chronograph.  What make it special there a printed chapter ring  which fits inside the recess of crystal before inserting into the case. I am thinking of a high dome crystal such as Sternkreuz ATCH, fitting diameter OD332/ID320.  For this purpose, tension ring will be removed and fit in the chapter ring.  I understand the crystal size may not perfectly fit these two dimension.  Should aim to find the right ID, then OD can be grinded to reduce without much difficulty.  To find the right crystal, the easiest way is to get know of the OD/ID relationship of Sternkreuz ATCH/ATCG (otherwise the OD of the crystal and tension ring).  I hope you are able to help to minimize the trial and errors.
