Strange marks on case-back
Just had an eBay purchase arrive, an Enicar military style, so I thought I'd have a quick look. When I took the case back off I noticed some strange marks, almost like the metal had been discoloured due to heat. However, if you kind of squint at it the almost look like letters??? The movement itself is fine. Maybe some marker or ink that has degraded over time or reacted with moisture??
Any ideas out there?
Pictures below:
Pictures below:
What be on tuther side of yon watchback matey ?
Pictures below:
The owner's initials. Oswald Clutterbuck ?
3 hours ago, Galilea said:
Perhaps someone burned something like incense in it, or used it for heating or melting something unhealthy. I have a nephew who has spoons that are similarly discolored. 🤭
The caseback was on pretty tight, I needed to use a special tool to free it up, so I can think of easier ways to heat stuff up eg spoons, hence, I suspect @oldhippy was correct and it is some kind of ink that has degraded over time, wen I get home from work I'll try to remove it with acetone which will confirm if it is some kind of ink or heat effect. The good news is that the movement doesn't seem to be effected 🙂
Of course @oldhippy and you are likely to know. I happen to associate war with hard drugs, trenches and limited resources, and this is a military watch I think you said. Forgot to say first time: nice looking watch. I wish I had one lol.
Its through to the outside, ink wouldnt do that . Sorry just woke up .Actually was marked from the outside. The initials are J.C.
Edited by Neverenoughwatches
😲 Swiss stigmata?
Its not military Ness, the case shape is different for that much heavier. Just military style, trying to copy some way with a black face .
It looks more like it was engraved and the heat from that has scorched the inside, but definitely marked from the outside.
16 minutes ago, Galilea said:
😲 Swiss stigmata?
12 hours ago, Waggy said:
Here you go
Pictures below:
Its a Durowe 422 1950s.  Enicar did make miltary spec watches. Even though this isn't doesnt mean to say it wasn't used in the military, soldiers  often wore their own.
As it is also on the out side, how ever the e
I agree but there is no sign of heat on the outside or any sign of buffing on the back. Could be one of life's little mystery's.
I thought maybe one of those small engraving pens might just generate enough heat to tranfer a scorch mark to the inside. 🤷‍♂️
Best guy to speak about Enicars and to watch is Matt from Horology Biology.
Small world, that's the reason I got this one, he seems to love them, so I thought I'd get one to see if I agreed with him. I also created a post on this forum on watches flying under the radar, so I'll add this brand as one such sub-radar brand if I agree with Matt.
Most definitely heat markings from the engraving on the outside of the caseback. The gradient of the colours perfectly match the colouring reaction of steel across increasing temperatures. Blue at the hottest point (the actual initials), surrounded by purple, then red-brown, then yellow-beige. See the image below.
Probably engraved it, and polished away the discoloration of the steel on the outside, but not the inside.
    • The problem is that this movements were not produced with the modern level of standartization, there for parts from one didn't fit well to another, even if they may look the same. May be it doesn't concern the winding stems, but yet there are not spare parts for such movements in supply companies, not even clear calibre identification possible. And where calibre identification  is possible, there are no Ronda numbers for the balance staff or the winding stem for this calibers in the data bases.
    • That black stuff - I had similar things happen with evaporust!  In that case I understand the evaporust eats the iron oxide away without hurting the metal but it can leave behind a layer of carbon which was in the steel that got oxidised. I spent ages trying to perfect a cleaning regime with various different stages in jars in an ultrasonic bath. In the end I switched to washing all but the balance and pallet fork in IPA and gently brushing it with a small artists brush.  I would estimate that I have found an extra 20º of amplitude doing this! It also takes me no longer than waiting hanging over a tank to move stuff to the next jar If it is really bad then I have used the IPA as a prewash and go through my old routine
    • I thought is FHF. Sounds good to make winding stem by myself but I am not in watchmaking on this level. 😄
    • At a friend's request, I've obtained a key for her long case clock which has been silent for some years. On winding it, the weight only rises a foot or so from the floor - & is not visible above the lower panelled section - before the key meets significant resistance. However it then runs quite happily for a day or so by which time the weight is again on the floor. I haven't had the chance to examine the movement but would be grateful for suggestions as to what might be happening here.
