Strange marks on case-back
Just had an eBay purchase arrive, an Enicar military style, so I thought I'd have a quick look. When I took the case back off I noticed some strange marks, almost like the metal had been discoloured due to heat. However, if you kind of squint at it the almost look like letters??? The movement itself is fine. Maybe some marker or ink that has degraded over time or reacted with moisture??
Any ideas out there?
Pictures below:
Pictures below:
What be on tuther side of yon watchback matey ?
Pictures below:
The owner's initials. Oswald Clutterbuck ?
3 hours ago, Galilea said:
Perhaps someone burned something like incense in it, or used it for heating or melting something unhealthy. I have a nephew who has spoons that are similarly discolored. 🤭
The caseback was on pretty tight, I needed to use a special tool to free it up, so I can think of easier ways to heat stuff up eg spoons, hence, I suspect @oldhippy was correct and it is some kind of ink that has degraded over time, wen I get home from work I'll try to remove it with acetone which will confirm if it is some kind of ink or heat effect. The good news is that the movement doesn't seem to be effected 🙂
Of course @oldhippy and you are likely to know. I happen to associate war with hard drugs, trenches and limited resources, and this is a military watch I think you said. Forgot to say first time: nice looking watch. I wish I had one lol.
Its through to the outside, ink wouldnt do that . Sorry just woke up .Actually was marked from the outside. The initials are J.C.
Edited by Neverenoughwatches
😲 Swiss stigmata?
Its not military Ness, the case shape is different for that much heavier. Just military style, trying to copy some way with a black face .
It looks more like it was engraved and the heat from that has scorched the inside, but definitely marked from the outside.
16 minutes ago, Galilea said:
😲 Swiss stigmata?
12 hours ago, Waggy said:
Here you go
Pictures below:
Its a Durowe 422 1950s.  Enicar did make miltary spec watches. Even though this isn't doesnt mean to say it wasn't used in the military, soldiers  often wore their own.
As it is also on the out side, how ever the e
I agree but there is no sign of heat on the outside or any sign of buffing on the back. Could be one of life's little mystery's.
I thought maybe one of those small engraving pens might just generate enough heat to tranfer a scorch mark to the inside. 🤷‍♂️
Best guy to speak about Enicars and to watch is Matt from Horology Biology.
Small world, that's the reason I got this one, he seems to love them, so I thought I'd get one to see if I agreed with him. I also created a post on this forum on watches flying under the radar, so I'll add this brand as one such sub-radar brand if I agree with Matt.
Most definitely heat markings from the engraving on the outside of the caseback. The gradient of the colours perfectly match the colouring reaction of steel across increasing temperatures. Blue at the hottest point (the actual initials), surrounded by purple, then red-brown, then yellow-beige. See the image below.
Probably engraved it, and polished away the discoloration of the steel on the outside, but not the inside.
    • Hello, I am just starting to learn how to hopefully service mechanical watchs Right now I started by acquiring a bunch of tools and a first practice movement (ST36).  Since I got it last week I have been practicing disassembling and reassembling it (I don't yet have the tools and products for washing and lubrication as I estimated that the first step is the manipulation required for assembly and disassembly). To be quite honest the result have been interesting.  My first step was breaking the setting lever screw when I was trying to remove the stem (OK practice movement won't be able to set time, oh well). I did manage to mostly disassemble the movement (I kept the balance together, didn't open the barrel and didn't remove any jewels). I messed up the balance spring a bit when removing the balance (I think the impulse jewel was still in the fork or something). There was  a small tangle. I reassembled everything and surprise the movement came back to life. I disassembled it again and decided I will try to fix the hairspring.  So with lots of trouble I removed it from the balance and when trying to fix it I made more of a mess.  After reinstalling everything the balance won't oscillate (likely the spring rubbing on things, either the plate or the cock). Right now I wait for my second st36 and continue practicing while slowly buying what I need to wash parts and lubricate them.   Any of you think there is a chance I can repair that spring or find a balance complete for that movement which will cost less than the whole movement?
    • Hello, I am a software engineer and all day spent in front of my computer makes me want to do something more manual as a hobby. I like the mix of intricacies and basic technology of mechanical watches, the fact that such marvel could be built manually hundred of years ago fascinates me.  So I decided to combine the two and learn "watchmaking"  (between quote as I don't expect to ever be able to make a watch). My first goal is to be able to service a mechanical watch. My current status is that I am pretty good at breaking small parts in watch movements
    • Nothing special to the horological world, but this is my travel watch. For whatever reason, this watch has accompanied me through airport security more often than my appendix and gall bladder. I feel as if i need this with me as much as my passport.
    • Apologies for digging up an old post but I am thinking about doing the same. Can I ask the OP what medium he used on the wheel. Was it a sanding disc and polish and if so what grades. Thanks.
