Movement "suddenly" stopped working after dial switch
Hmm ... I can't find anything with a pin like this. I guess with a lathe I could make the pin, then drill a hole in a regular mainspring and rivet the pin to it. Can't really see me doing that without a watchmaker's lathe, though. Am I going to have to shelve the watch because I can't replace the mainspring? There has to be another way.
Looking at the genuine Bergeon holder I expect the 0.8mm will be too big. Edit You should be able to check with the pins out of the holder if they pass through the surround to the jewel.
Thank you. Is there anywhere I can read a crash course about de-magnetisers?
