My first true project watch. Really nice condition vintage Seiko 7006a. Non running.
The Barrel measures 21.75mm and the biggest Watch-Craft winder is 16.40mm The Winder is of a Swiss made watch so maybe Bergeon would be the only option, I know the did a Clock set that satrted at 21mm and that one just looked like a bigger version of their current winders.
By Embezelled · Posted
Thank you! Oh and too late to edit out some typos, but "will perhaps a Seiko Crown" was supposed to be "will perhaps get a Seiko Crown". And I realize now that A-O3 should be AO-3. -
Yes, good advice! Or dig through all my threads on the forum to read about misadventures with American pocket watches. You end up needing many additional vintage tools succeed with most old pocket watches. And if you have already worked on the ST36 a few times then you have already built the tweezer skills needed for wristwatch movements. Return to the railroad watches once you are accustomed to hunting for tools and parts.
As they say, you learn somthing new every day Just before I consine this watch to the bin of regrets 😉 I thought I would share some onominolies I found Although this was a Pin Palet watch it didn't follow the norm (as far as I have seen so far) as can be seen in the picturs below there is no impulse jewl on the balance and the palet almost looks like its upside down, with the horns lower than normal with a small brass wire acting like a single banking pin. Not seen this before, does this style of escapment have a special name.
