Seiko Crystal Help!
Hello everyone,
Trying to wrap up a service on a Seiko 6309-8970. I've tried to locate a replacement crystal with no luck. Most of the sites are a bit confusing regarding the correct crystal for this movement. The part number is 310T40ANB0. I thought I had one located from S.T. Supply but it is no longer available through them.
I would buff out the crystal in hand but it has quite a few shatter cracks which I would not be able to remove or repair.
Any help would be greatly appreciated.
Ed...
Heyo, looking at Jules Borel parts list for that movement/case they reference an alternate code for the crystal XAG 311.649 with a link to purchase it here:
http://www.julesborel.com/s.nl/it.A/id.20940/.f
Looks like it's yellow though? I'm not sure. Maybe you can contact them and find out what other options there are.
    • All I do is use a fine marker (sharpie) to put the service date on the back cover, this way it can be removed with some IPA and does no permanent damage to the watch. I'm in two minds about the whole service marking thing, sometimes it's good/bad to see the markings on the watch case back as you know it's been worked on and vice versa. However, if I took my car in for a service and the mechanic scratched some code into the housing of my engine I wouldn't be too impressed. Hence, I think my sharpie solution is a reasonable compromise.
