Do i have to remove these jewel covers to oil the jewels?
Okay anything else I can use? Vinegar? I used isopropylalkohol but without luck even though it was good on the watch case for removing melted gasket. I dont have naptha.
By watchweasol · Posted
Hi Guys. None of mine are fit for public consumption and I don’t want putting in jail at my age. If I find a passable one I will slide it under the door. So watch this space. -
Hi cleaning any rubber usually takes the surface off it a bit. Try a little IPA OR NAPTHA. ( lighter fuel) -
If you look like your passport photo, you’re too ill to travel 😂 Tom
By LittleWatchShop · Posted
I have pondered such a plan. The unfortunate aspect of my 3d printing is accuracy. Not so great. So if I print something that works, I am almost guaranteed that the dimensions are not what was drawn. My purpose, even if inaccurate, was just to get a feel for the fit. I will look in to these service providers, though. Bear in mind, however, that part of the joy (if not all of it) is solving this myself. Otherwise, I just go mow the lawn or split wood or some other mundane task.
