Hello,
I have a Heuer stopwatch with a minor issue - the spring on the cam of the minute hand has snapped and therefore the hand no longer turns when the stopwatch is running (it is otherwise running fine).
Firstly - is there a specific term for this part or is "cam spring" a good descriptor? I've been trying in vain to find a replacement!
Broken spring removed from cam
Broken spring next to second hand spring
Appreciate any help!
