I have worked mostly on Timex watches but recently  I was asked to repair a family heirloom Wittnauer watch.  The watch fell from a mantel and broke the crystal.
I have seen this style  watch on eBay  (called on eBay  - WIttnauer Assymetrical Watch). eBay listings suggest that this may be form the 1960s  However I have not been successful in identifying the model based on the case back information.  I cannot seem to find any info on models or replacement crystal numbers.
The watch is very accurate.  It does not appear to have been touched before.
As you can see from the photo of dial and case front, the crystal would be wider at the top than at the bottom.  The  opening for the crystal   is very slightly curved outward on all sides.
Any advice on what crystal would fit this watch and on what the numbers/lettes on the case back mean??
Thanks,
Keylessworks
Sorry for misspelling Wittnauer with an "M"
